Removing VNB front mudgaurd?
djh66
Main scooter: 150 special
I've removed the forks from frame, and all the bolts associated with the mudguard, and I realise you have to get it at the right angle to remove it, however, the dust cover for the bearings is stopping it being removed! Any ideas?
Bring Me Sunshine COYH
CPH Lambretta
Main scooter: DL 150 1970
Remove the lower bearing and dust cover, then it will come off a treat.
Slow is the new fast!
djh66
CPH Lambretta wrote:Remove the lower bearing and dust cover, then it will come off a treat.
Thanks CPH, I applied a bit of heat and the race and cover came off lovely.
