Series 2 headlamp 'gem'.
Anyone got any tips for fitting the small plastic 'gem' into the headset top of a series 2 ?
Tractorman
- Main scooter: Lambretta li150 special
Clear silicone sealer.
Hi,thanks for the reply,the problem i have is getting the so**ing thing to fit in the hole,i assumed it would just 'click' in,ive tried shaving a bit off the sides,but no luck!,probably just another example of poorly re-made parts!!
- barnsleybilly
- Main scooter: Li200
I bought about 3 red ones and found none of them would fit, only when I bought a Casa standard green one did it just pop in.
Agree with fixing it with silicone, it's great stuff! If its good enough for the Space Shuttle (well the ones that didnt blow up) its good enough for a Lambretta.
Strangely enough,these that i have are red ones!!
dapper
- Main scooter: The Biriani Bullet
Just tried fitting one to a lad's scoot I'm doing up and the fecker broke straight away as it's too big for the slot. I've now ordered two more (as I'm sure to break another fecker) and will carefully and time consumingly fettle it to fit
dapper
Update. Just got two green gems in from SR and fitted one straight in (headset is green anyway) The clear one that broke seemed to be more brittle plastic. They do other colours too if that helps.
I bought one from scooter restorations. Fitted no problem at all : )
Thanks all,i ended up filing the sides all round then fitting with the silicone.All looks fine so far!
