programmable cdi
What's wrong with one of these? Fully adjustable to your desired adv/retard choice:
http://www.sip-scootershop.com/Products ... Vespa.aspx
fishi
drunkmunkey6969 wrote:What's wrong with one of these? Fully adjustable to your desired adv/retard choice:
makes same things as the AGUSTO !!!
fishi
fishi
Yes, but the Agusto isnt adjustable, the AddonV is.
fishi
fishi
yes, you are right, this is what the AddonV can more:
http://www.germanscooterforum.de/index. ... 1066135504
im talking fully programmable with the choice of a throttle position sensor so you can adjust everything every 5% throughout the whole throttle opening every 500rpm , you will have full control of your ignition,revs,power valve ,throttle position, liguid cooling temp ,speedo and more .
CANbus
mark wrote:im talking fully programmable with the choice of a throttle position sensor so you can adjust everything every 5% throughout the whole throttle opening every 500rpm , you will have full control of your ignition,revs,power valve ,throttle position, liguid cooling temp ,speedo and more .
yes my intentions are to have fully electric throttle control, clutch and maybe even gear change. By using a hall effect speed sensor on the mag I hope to profile performance based on rpm and also gear selection. The challenge will be to make it an enjoyable ride.
11111111 = 0xFF
Adspeed
I know you guys are talking serious tackle here.
Just to let you know the Chiselspeed Advance/Retard unit is in the dealer section.......
i also have a full mappable setup on a smallframe of mine. Dyno testing is coming soon hopefully. But as said before I think it'll be iceing on the cake rather than massiveadvances.
fishi
to david:
any news refering your RM250 igintion ???
From which model is it? Where do you got it ?
Does this ignition need a battery to work ? it looks like it need one.
Some photos are also of interess!
Have send you PM, but no reply!
fishi
joee
may i just add...i have not got a danny what the hell you lot are talking about??!!
carry on
randall ate my dog!!
no one likes us we dont care
    Users browsing this forum: Ahrefs [Bot] and 5 guests
