Dodgy steering bearings.
10 inch Terror
Xbox live gamer tag: No.
Hi all, has anyone come across upper steering bearings that are too small to fit the cone and race? I've just tried fitting a set and they are too small. I've tried them in 3 races and 2 new cones and they are too small in all of them. It's not a major deal I know but it's frustrating as they are supposed to be 'top quality' and I've had to order another set which has now slowed my rebuild up.
fairspares
thats how the top bearings come now, fit them and then tightened gently, undo and you will see they fit in the top bearing ring.
10 inch Terror
fairspares wrote:thats how the top bearings come now, fit them and then tightened gently, undo and you will see they fit in the top bearing ring.
I tried that and the forks were very stiff. I'm now going to split both bearings and fit them 'loose' hopefully that'll sort it. Thanks for your reply.
Jxmiddle
Main scooter: GP250 69 targa twin
I fitted the bearing loose and the difference in feel is significant. Bit of a pain to do but worth the effort imho.
Minority
Main scooter: Li230 S3
The other benifit of fitting loose bearings is that you can fit more ball bearings in if you want to. This distributes the load better and the bearings should last longer.
10 inch Terror
I fitted loose bearings to my other Lammy and to be fair it was a pain to do. This is the reason I was just going to fit them as they are on this build. Looks like I'll have to bite the bullet and fit them loose again.
