34mm amal jetting
spannerman
Hi all, just servicing an SX200, its running very, very rich!
this scoot was built more than 10 year ago and has finally got on the road.the carb is a 34mm Amal Mk2 .
anybody know where I can get info for jetting ,as I feel this has just been chucked together,its actually jetted higher than my TS1, also running an AF 44mm clubman
kevspeed
Standard barrel,or something else?
spannerman
standard barrel,supposedly worked by Harry Barlow (proporting)
power jet or non power jet ?
spannerman
non power jet, are there any sites that list this info ?
speedy
AF used to have a jetting guide on their site, which had plenty of info for Amals, but alas , I just been on there and it's a blank page.
spannerman
yep,thats where I have gone before,A/F said that due to changes in modern fuels it was misleading and took it down
gaz_powell
I have the AF chart
there are no details for a 34 Amal on a standard 200 barrel but the following are listed
30mm 200 with clubman
mj 300-320
needle jet 107
needle 2D1
SLIDE 3-4
PILOT 35
CHOKE 50-55
MIXTURE 1/2 TURN OUT FROM STOP
All the listings for the 30 or 34mm amal are the same except the mj
hope this helps
Gaz
spannerman
Any chance of sending me a copy of the chart Gaz?,just picked up a 32mm amal that might work better,think the 34 is way too big
By the way thats not far off what its jetted at
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 7 guests
