old scooter
wrecklessrobbie
Main scooter: li150
I bought this 10 years ago. Done nothing with it. Was sprayed over and bits welded by someone in Spain during its life. Not sure what to do with it.
http://s273.photobucket.com/user/robbie ... sort=3&o=0
What are you thinking?
Looks quite solid, get it up and running and run as is?
wrecklessrobbie
Main scooter: li150
Its solid and mainly straight. Carb and speedo missing, otherwise all there.
Agree looks a great base for a project
Scootissimo
Series 2 Street Racer - stick a set of drops on it and a kit the engine!
Wide boys look great with race paintwork too!
wrecklessrobbie
Main scooter: li150
I started on the strip down. Not sure how to upload to photos to show on here.
Bolt on dampers?
http://s273.photobucket.com/user/robbie ... ort=3&o=10
Battery tray cut off?
http://s273.photobucket.com/user/robbie ... ort=3&o=12
Fork bumpstop broken off. I couldn't remove the forks til it fell out.
http://s273.photobucket.com/user/robbie ... sort=3&o=6
wrecklessrobbie
Main scooter: li150
How do I add photos?
I'm a techno phobe.
Robbie
DaveTomo
Main scooter: SX 200
wrecklessrobbie wrote:I bought this 10 years ago. Done nothing with it. Was sprayed over and bits welded by someone in Spain during its life. Not sure what to do with it.
wrecklessrobbie wrote:I started on the strip down. Not sure how to upload to photos to show on here.
Bolt on dampers?
When you add the picture you want to use the 4th option down IMG, left click on it (it will highlight in yellow) then paste (right click on here) that and it will show the picture. If you want to double check hit the preview button,before you hit submit to see what it looks like before you post,to make sure you've got it ;)
wrecklessrobbie
Main scooter: li150
I'm on a hudl tablet.
Am not sure how to do it.
I'm thick.
I have rebuilt my forks.....I have fitted a new lower bearing race/cup. The original was slightly pitted. The new race is loose on the shaft ( story of my life ). When the bearing goes on which I presume is steel frame down the race spins as well as the bearing.
The forks I have are Spanish.
Do I need another bearing race? Are they different sizes?
wrecklessrobbie
Main scooter: li150
PS thank you Dave tomo. :)
