air leak thru the spark plug
scooter_italiano
Main scooter: Lambretta SX200
At the end of a 200cc kit rebuild I've found an air leak coming thru the spark plug hole.
Putting grease around the threads of the spark plug seems to improve sealing but the leak is still audible. any suggestions?
grazie!
nelson pk
If its an old plug, the sealing washer on the bottom could be crushed beyond sealing if you know what i mean. Try a brand new plug if its an old one.
Trojan
Main scooter: LAMBRETTA INNOCENTI
The spark plug washer may do for now, but the downside may be the threads are worn in the head due to overtightening worth a look....... 8-)
scooter_italiano
Trojan wrote:The spark plug washer may do for now, but the downside may be the threads are worn in the head due to overtightening worth a look....... 8-)
that's true but for now it works! ;)
grazie mille! :D
