Snapped crank
psychedelicropcircle
MB does a good job of these.
joespeed
can you show us more photos of the cylinder skirt,it looks like it has knocked off the thinner machined spigot,this may not impede the running of the kit!
Ian Hepworth
It's not the worst damaged casing I've seen but it's a fiddly repair. It needs building up with weld then the crankcase mouth and gasket face need sorting.
The cylinder could be repaired with a steel liner.
dapper
Would have thought Oiltek could repair this.
Muppet
get it welded it'll be rite :P
C’est la vie
vicvega
Main scooter: Scomadi
https://www.flickr.com/photos/127594304 ... 153656401/
https://www.flickr.com/photos/127594304 ... 156232382/
https://www.flickr.com/photos/127594304 ... 133596316/
Closer pics of the barrel, you can still see a piece of the rod embedded in the side wall. Is it possible to salvage this, the head is perfect no damage at all. :?:
joespeed
steel liner should fix the cylinder,
lambro
langcourts in Weston Super Mare can repair the barrel, and re-nicasil it.
If you don't want a steel liner that is.
Shaun.
    Users browsing this forum: Ahrefs [Bot] and 4 guests
