Wassel Failure
obviously you have changed HT lead and plug cap?
also checking the pickup and ht coil with a multi meter isn't always 100% true,,, I have a stator that test good which ive carried round for nearly 2 years as a spare, earlier this year a mate of mine needed to change his stator on the way to Whitby so he tried my spare, it didn't fire at all, in fact it didn't spark at all. when I got home I tested it again on the multimeter and it still showed good readings.
petrol tap.
Come on then Bilko, we give in, what is wrong with it then?
have you tried an air test on it yet? pretty easy to do even with out a kit just by using innertubes
- Monty
- Main scooter: Series 1 Muggy, Imola Special
Out of all thats been done and checked I can not see any mention of CDI. I went through the mill with timeing and different stators earler this year. I tried 3 stators and found the timing moving all over the place simply changing the cdi. I used expensive and cheaper ones but in my case timing could easily change by 10 degrees simply changing the cdi. This in conjuction with an M tech got me thinking they were a waist of time. All stators metered out OK. I settled for a BGM one in the end the next step was to mount it on rubber buffers after comments about vibrations. Like you I seem to have spent the summer in the shed. Good luck.
- Information
Who is online
