small block virgin
YAMLAM
I`d go with what you got, nothing wrong with Li125 box , use a 16 tooth front as suggested.
win or lose have a booze
wurzel
Main scooter: TV 175 / JET 200
Thanks for the advice gents, much appreciated
Li 125 box has 5.65 final drive with 15 x 46 std sprockets. To reach 60mph you'd have to be revving it to 6700 rpm, on a dyno in 3rd gear maybe but on the road with a heavy rider, in your dreams. You need 5600 rpm just to get to 50.
With a 16 tooth front sprocket 60mph would come up [again in theory] at 6300 rpm, and 50mph around 5250 rpm.
Given that a reasonable cruising rpm for this set up would be around 5,000 rpm that equates to 45 mph with 15 x 46 and 48mph with 16 x 46.
In the real world lots of other factors contribute to not being able to match those numbers on the road.
It'll go much faster with an Indian speedo though.
Bilko
Main scooter: LI150
corrado wrote:It'll go much faster with an Indian speedo though.
:lol: :lol: :lol:
Bilko's Oily Blog
Id spend £150 on getting the cases converted to 200 and an indian stg4 200 kit which are preety well proven and a 30mm carb and decent pipe can give very good figures
