Drive side seal retainer
hendy
In case its ever of use to someone else......
Two problems:
Firstly, the halite washer I had was 2.5mm uncompressed as oppposed to 1.5mm uncompressed on the new one.
Secondly, I used an mb retainer plate which is 0.7mm thinner.
After I had finished I only had 0.6mm clearance betweeen the crank and case. Minimum is 0.5mm. It doesn't take a genius to work out that neither solution would have worked in isolation.
HxPaul
I've always found that halite gaskets in the MEC gasket sets are too thick.
camel
Are you using a drive side bearing with a built in seal?..I've done without the hallite washer in the past as the combination of the both were too thick
