Needle or Atomiser ?
paulnobodyimportant
Main scooter: varies
Adam
That's probably why I'm struggling, just re-jetting since putting on a Ky-Tronik advance/retard unit
Tom Russell
Dellorto sell all sorts of drill bits, reamers and measuring tools :-)
Adam_Winstone
Hi Tom... good to see your name in the top 3 for Scootering race reports... spot on :)
My concern is that we are talking very small, very accurate modifications needed and I'd rather pay someone to get it right/accurate during manufacture, rather than me bugger it up!
Adam
Tom Russell
Adam_Winstone wrote:Hi Tom... good to see your name in the top 3 for Scootering race reports... spot on :)
Adam
Thanks Adam and yep fair comment! :-)
Adam_Winstone
That said, I've found that X2, X13 and X7 needles can vary considerably on shaft diameter, even though they are supposed to be the same. I guess I might be better to accurately modify parts myself, rather than blindly trust even Dellorto's quality control!
nelson pk
I Agree that it is a shame that you can't get in between sizes on the atomiser for PHBH however some tuners can modify them although you will get charged more than a standard atomiser...
For example I wanted to go to VHSH but the carb would not fit with my set up without fouling my fuel tank so to set up the carb as best as possible a tuner made an AV269 for my set up.
I guess Dellorto see the round slide carbs as dated as they DO make in between sizes for the flatslides.
YAMLAM
the 2.65mm reamer arrived today, i`ll get a couple of AV264 modified.
win or lose have a booze
Adam_Winstone
Please give us some feedback on ease of modification and accuracy, if you have a way to measure?
Well done :)
YAMLAM
Just had 4 atomisers modified, sending one of to Adam today.
Adam_Winstone
Ooh, like that :)
Ta
