T5 indicator probs
carbon lammy
T5 classic rear indicators come on but don't flash,front ones flash as normal,new indicator switch and flasher unit fitted,wiring checked earths cleaned and checked if I swap wires on switch rears flash and fronts stay on,any ideas what's wrong
firekdp
Is the headset tell-tale light working ok?
I think I read somewhere that the T5's indicators flashed alternately front/rear so that only one lamp was on at a time. That was supposed to limit the current drain and stop the headlights dimming? I did have a T5 but when the indicators developed a fault I changed the flasher unit and the new one definitely flashed front/rear at the same time and I hadn't noticed what the original one did before it failed :? The reason I mention it is if true, that might explain how front and rear could operate differently.
carbon lammy
No mate tell tail not working
lambro
Check the buzzer wires in the tool box haven't connected and taken the red to earth.
Had that once.
soulboy
relay behind spare wheel
carbon lammy
Demented now I've changed every indicator part on my scooter,checked continuity of every wire still not working rears flash as normal fronts just come on and don't flash anybody any ideas what's wrong,tell tale does not flash but bulb and wiring ok as is speedo wiring,help
Norrie Bodge
Could be a regulator fault maybe??
Try 4 12v 10w bulbs see if that helps
carbon lammy
I have mate it's not that
lambro
Do a continuity test on the red feed wire, buzzer end will do and see if it has gone to ground.
Exactly the same fault on a mates, and thats what it was.
Worth a look.
    Users browsing this forum: Semrush [Bot] and 8 guests
