Fork links
- corrado
- Dealer
- Main scooter: Lambretta GP
You can get GP ones in without the compressor [just about] because of the loose balls on the spring rod but with fixed ball type of the SX/Li is near impossible and that's with the forks out. Dropping the forks is the easy part.
Norrie Bodge
- Main scooter: GP-1971-Ts230/S2-1960-Ts230
Sorry to hijack on this thread?
Regarding GP buffers, im just in proceess of doin mine, & where the bottom buffer clips in on one side this has come away..
is this essential to keep the buffer in place??
- paulmgreen
- Main scooter: Lambretta Group 4 Race 200
Yes "
www.JPPLambretta.co.uk
Norrie Bodge
Cheers on the reply...paulmgreen wrote:Yes "
Can this be fixed??
You can get new buffer clips but they need welding in or you can fit theearler type of buffer that are fitted in with bolts butyou needto drill the forks for this
- paulmgreen
What Shocky says !
Norrie Bodge
cheers m8shocky wrote:You can get new buffer clips but they need welding in or you can fit theearler type of buffer that are fitted in with bolts butyou needto drill the forks for this
U know who does them??
What the drilling if so its something you can do your self the buffers are the LI/SX type
Norrie Bodge
id rather keep as std
does anywhere does the GP type & ill weld them in m8
cheers
cheers
