GP stripped headlight thread
Snails
Hi
I've managed to strip the headlight thread on my GP headstock. I'm thinking of repairing the thread myself using this
https://www.machinemart.co.uk/shop/prod ... it-m4-x0-7
Do I have the correct size thread for this bolt?
monument7
Main scooter: Li auto conversion 180
Expensive for one thread innit, don't you have a welder nearby or open the thread up to 5mm. I know it's not original but neither is a helicoil.
gaz_powell
just done one for a mate - i drilled out the lugs neat and put 3mm rivnuts in with araldite surround - its a clean operation doesnt damage the paint and you have the correct thread and no expensive tools
worked a treat
essexgp
I got some nuts the same thread as the origonal screws and fixed them behind the lugs with i think its called "steel weld" glue. Once it had gone off worked a treat, been on there a couple of years now
Used to use araldite then drill and tap it
jonny wadd
Xbox live gamer tag: swingin meeet
Main scooter: lambretta gp200 electronic
Same fix as essexgp works a treat and much easier than drill and tap also a strong long lasting repair
milf hunter
hendy
just buy the helicoil kit. You've heard of them haven't you?
Do you know why you've heard of them? Because they're famous.
Do you know why they're famous? Because they're great.
I've been working in engineering maintenance and commissioning for 30 years now, so I'm not just spouting off. These things are used on expensive machines the world over when things go wrong and they work. Simple as that.
sydduckett
RB gaz on here will go halves with you, he's got his taped up with masking tape and it's looks sh$t..... :D
He will be along shortly to admonish me for the above comment.... :lol:
connormanuk
I used jb weld on mine , filled the screw holes with it ,drilled it and re tapped to m3
    Users browsing this forum: Majestic-12 [Bot], Semrush [Bot] and 5 guests
