tuning a dr kit
ducksta
well the time has come for me to get the dremmel out, never tuned a cylinder/piston/cases before, got a new dr kit +descent exhaust 24/24 carb so any advice before i go too far
paul d
Main scooter: T5 172 Tv 240
Before any creativity I'd file the edges off all of the ports in the barrel, DR's have sharp edges! Also a quick hone to give 4thou clearance helps to stop piston seizure. Don't worry about the piston slap. BBQ painting the barrel black helps with cooling. 21 tooth clutch helps with top speed. Take your time breaking it in!
fastfrog
Plenty of work to do on a DR barrel.
Lots of power outta it...
Size matters!
fastfrog
before with small combustion chamber
After:
Size matters!
paul d
What a work of art! Am I looking at bridged exhaust ports? If I was the owner of DR I'd hire you on the spot!
fastfrog
many thanks mate. lots of meat to grind.... And absolutely no risk of passing through...
Size matters!
ducksta
spot on do you have a port map for the barrall
fastfrog
unfortunately not. Engine has had different owners by now. Still running great.
Size matters!
fastfrog
Pmax at 7600 rpm.
timing:
T:130°
E:185°
I: 195°
Size matters!
fastfrog
this one shows the main difference between opened ports and the shut ones.
Size matters!
    Users browsing this forum: Majestic-12 [Bot] and 17 guests
