Will I gain anything?
Andy W
Main scooter: GP 186 Imola
I have been offered a 32mm OKO/PWK flatslide carb and LTH inlet manifold to go on my Imola kit, question is will I gain anything from fiitting these parts? currently the spec is:
Imola 186 kit Fast Road tuned, 30mm PHBH, Fran Race making 21+bhp.
What gains are there to fitting a flat slide carb and do you gain anything from the inlet manifold?
Cheers Andy
ducksta
will i gain anything, depends if your currant set up is sound if yes leave alone if not you got nothing to lose
goldeneye
I changed from a 30mm PHBH dellorto, to a 28/30 (oval bore) KOSO (sort of mid way quality between an OKO and a PWK) and mine is more responsive , better fuel economy , revs on better , and was easier to set up than a delly (using BGM JET KITS at not a lot of money) I'm happy with mine (proper stage 4 , home made clubman)
The PWK is a shorter carb than the PHBH and the LTH manifold is shorter too so it would probably allow for the fitment of an air filter under the panel.
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1 guest
