TV200 IGM number?
gerryjunior
- Xbox live gamer tag: no
- Playstation gamer tag: no
- Main scooter: lambretta li 2
tv 200 no igm and tv 1 no igm , as far as i know.
- gix
- Main scooter: Lambretta SX150 1968
The reason they have a TV2 engine number is because the TV175 series 3 engine casings couldn't take the 200cc barrel, but, the series 2 TV175 engine casings could, so they made a decision to use series 2 TV175 casings.
1968 SX150 Apple Green
scooter_italiano
- Main scooter: Lambretta SX200
I don't know how the frame numbers sequence worked but doing 512000 + 14982 the last TV200 should be 526982 but my TV200 starts with 54.... as several others so yes they were built at the same time.bristolmod wrote:TV200 and TV175 were made in batches and its impossible to say which numbers were allocated to which. TV200 apparently started at 512*** onwards and TV175 started at 500000 (Scootopia had 500010 a while back!)gix wrote:TV2 followed by numbers starting 512*** the only made 14,982
Its impossible to say, for example, that 524186 was a 200 or a 175.
do you mean that a Series 2 TV175 engine could accept a 225 barrel with no modifications?!gix wrote:The reason they have a TV2 engine number is because the TV175 series 3 engine casings couldn't take the 200cc barrel, but, the series 2 TV175 engine casings could, so they made a decision to use series 2 TV175 casings.
bristolmod
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
numbers of TV200 and TV175 did not run consecutively. i.e. between 500000 and 55**** 175 and 200's were mixed up- there was not a complete run of 14982 TV200's. Hence the earliest 200 was around 512*** and the last around 55****. In between were batches of TV175's.
Scootering since 1968.
scooter_italiano
I don't know never tried and I askgix wrote:no?
- DigDug
I tried to stick an SX200 barrel on a TV175 casing on the night of November 23rd 1970.
It was about an hour before any of the three people present thought to check the stud pattern with the head and found them to be different.
I was 16 on the 24th and was hoping to get my TV175 basket case on the road.
You live and learn.
You live and learn.
Did you have to do that?
bristolmod
Classic!- have to diagree about "living and learning"- if that was the case we would have outgrown these shopping trollys years ago!DigDug wrote:I tried to stick an SX200 barrel on a TV175 casing on the night of November 23rd 1970.
You live and learn.
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
I wouldn't buy one now, that's for sure. There are a lot of wrong ones out there. And you can usually tell.
