brenbo master cylinder
satans reject
Main scooter: lambretta gp
morning all,
these brenbo master cylinder seem to be the new next thing, (the green cutdown in this months scootering....) anyone one out there using one and which 'model'?
thanks
scott from morecambe
There's loads of different ones on the market of that style, the difficulty is in making it fit the Lambretta light switch housing. MB used to do a switch housing to mate up with these motorbike style fitment master cylinders.
They look odd to me unless you've got a hydraulic clutch and use a matching master cylinder for the clutch too.
soulster22
Main scooter: italina GP 200
Got one fitted on my GP and it looks the nuts. like the way you can adjust the lever inwards or outwardly and the master cylinder itself is a work of art.
will try to post an image later if possible.
regards Harry
Agent Buchwald
There are a lot of fakes around for those that like to make life more interesting than it really is.
"Brenbo" sounds like a fake to me, unless it's a tribute brake. :lol:
BGM one might be suitable ...
http://www.scooter-center.com/product/B ... tmatch=ALL
Looks good on a R1 sadly not on a lambretta. looks like the sort of thing someone would fiddle with when the scoot wasleft unattended
satans reject
soulster22 wrote:Got one fitted on my GP and it looks the nuts. like the way you can adjust the lever inwards or outwardly and the master cylinder itself is a work of art.
regards Harry
harry,
have you dug your camera out yet?
scott
Jonny mars bar
Main scooter: Gp rb250
Hi, it's my cutdown in scootering. Radial master cylinder is a brembo 16 x 18. It's probably the best bit of kit on the scooter. Loads of feel to the brake, much better than the Nissin type although Nissin radial ones are good they don't look as good as the brembo. I use an mb mount although you have to get it welded a little as the brembo mounting holes are off set slightly. I will try and post a picture up tomorrow.
You can get a radial master clinnder from ped parts, the same as the bgm ones..
Cheers jonny
soulster22
Jonny mars bar wrote:Hi, it's my cutdown in scootering. Radial master cylinder is a brembo 16 x 18. It's probably the best bit of kit on the scooter. Loads of feel to the brake, much better than the Nissin type although Nissin radial ones are good they don't look as good as the brembo. I use an mb mount although you have to get it welded a little as the brembo mounting holes are off set slightly. I will try and post a picture up tomorrow.
Cheers jonny
Good morning Gents, my master cylinder is the same as Jonny's and as requested i have attached a photo below. will send one of it fitted to the Lambretta later.
https://flic.kr/p/o5UJ3m
regards Harry
soulster22
regards Harry
harry,
scott
Morning Scott,
image of the brenbo brake assembly as fitted on my GP
https://flic.kr/p/nXiPJT
Regards Harry
    Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 3 guests
