bent layshaft
skoota2
Main scooter: lambretta gp
hi all have i got a bent layshaft,fitted new hub[good sil one] af rims run out 3mm :o
nastro azzurro
Will be the hub or rims, not layshaft. 3mm??? how did you notice that??? :o
nastro azzurro wrote:Will be the hub or rims, not layshaft. 3mm??? how did you notice that??? :o
I'm inclined to agree, could even be that the rim isn't seating properly due to thick paint or powdercoat. Easy to pinpoint by jacking the rear wheel up so that it can be rotated then use a suitable block of wood to hold a pointer against the centre point of the wheel nut and then the rim/tyre/hub to check for run out.
    Users browsing this forum: No registered users and 66 guests
