Horrendous scraping when kicking over
Are those bits alloy or steel they look alloy
vRSG60
Main scooter: Lambretta Li125 Lambretta GP20
They don't feel soft enough for alloy.
I get my kicks out on the floor.
Jazzy
Piston skirt.debris jamming the crank.
Don't force it or you could break the crank housing.
Assuming he'd have said if the piston was damaged in any way when you took the barrel off.
Looking like crank big end
Jazzy
First rule of this game is Asume nothing.
First time I lost part of the piston skirt the break was so clean it was hard to tell anything had fallen off.
vRSG60
Looking like big end. The only but I'm going to struggle to do myself, take the crank off :-(
bazza3004
If you have stipped it as you state so far im sure you wont have much trouble taking the crank out.
vRSG60
Well big end bearings gone definitely I can move the con rod about 10mm at the big end. Bugger and damn.
It looks like I need special tools for the crank. May as well take the engine out and take it somewhere to be done.
vRSG60 wrote:Well big end bearings gone definitely I can move the con rod about 10mm at the big end. Bugger and damn.
It'll be a bit easier with special tools but it's perfectly possible to remove and replace the crank with normal hand tools. I know as I don't have any 'crank' tools myself and have never had any problem. Just don't use a hammer directly on the drive side to knock the crank out if you want to use the webs again.
vRSG60
I'm assuming it'd be better to replace the whole crankshaft and not just the big end bearing?
