SIP Lambretta Digital Speedo
Tom Russell
Digital display has stopped working properly on mine - which runs off DC - (maybe something to do with rain at Exmouth over weekend) and I've only had it on scoot for 6 months, covering maximum of 1000 miles. My mates has also completely stopped working on AC. I've heard of a few others failing as well.
Great functional bit of kit, but poor quality, seriously p***ed of!! :-(
sideout
Tom Russell wrote:Digital display has stopped working properly on mine - which runs off DC - (maybe something to do with rain at Exmouth over weekend) and I've only had it on scoot for 6 months, covering maximum of 1000 miles. My mates has also completely stopped working on AC. I've heard of a few others failing as well.
Yeah, I got a bit wet coming back from Exmouth too Tom, and mine reset the trip a couple of times :( I put it down to water in the switch. That one's on AC.
Are the aforementioned issues with the MkI or Mkll speedo, I.e. with or without fuel tap light?
sideout
soulsurfer wrote:Are the aforementioned issues with the MkI or Mkll speedo, I.e. with or without fuel tap light?
Mine was the MkII in this case Mike. It was exceedingly wet though :(
victor
Main scooter: Tv175 but currently a SS210 :)
Where did you end up fitting the power box, and how? Double sided tape inside the headset?
Cheers V
Timbo
That's what I did, I have some spare if your interested.
Minority
Main scooter: Li230 S3
victor wrote:Where did you end up fitting the power box, and how? Double sided tape inside the headset?
Cheers V
I thought that it was a little cramped in the headset (plus I planned on an H4 Halogen conversion so hotter as well!), so I extended the cable and moved it down to the horncast held on with a cable tie.
victor
That looks ace - did you simply cut the cables, soldered in an extension and shrink wrapped it?
Also, is that a GP or SX? Which one has more space in the headset?
Minority
victor wrote:That looks ace - did you simply cut the cables, soldered in an extension and shrink wrapped it?
Yes that's exactly what I did, shrink wrap makes life so easy now!
And it's an SX type headset/horncast
Pepot
Main scooter: servetta LI150 serieIII GT186
I've fitted mine under the backbone using velcro. Very easy to reach the stator wires if you run a wassel.
    Users browsing this forum: Baidu [Spider] and 5 guests
