jetting for 42mm clubman
djh66
Main scooter: 150 special
I'm removing my Taffy, temporarily, and replacing it with a 42mm clubman, any advice on where to start on re jetting my 30mm Delly (no filter) on a gt 186 kit? Currently: 130 main, 55 pilot, x7 needle (2nd clip down), AV268, 40 slide.
Cheers
Bring Me Sunshine COYH
storkfoot
Mb clubman with a filter:
122 main, pilot 55, AV264 x13 2nd clip, 40 slide
djh66
storkfoot wrote:Mb clubman with a filter:
Cheers, that gives me a starting point.
djh66
I've now gone to AV266, X7 (2nd clip down) 55 pilot, 122 main
Not been out on it yet, but seems ok on stand air screw 2 turns out. Only niggle is when I twist the throttle quickly, from tickover, it burbles for a split second before it picks up, is this pilot too big or something else?
Donnie
U might find the x7 with the 266 is too much Dave I went x13 in the end.
Donnie.
djh66
Donnie, in what way too much, do you mean too rich? I thought (although I'm probably wrong) that the X13 was a richer needle than X7?
Donnie
It is richer but I think the 13 will work better mid range than the x 7 with a av266.
On saying all that, until you ride it you wont know :-/
Donnie.
    Users browsing this forum: Semrush [Bot] and 11 guests
