Vhsh
lou
Slight Concern ....running standard ts1, pm28 pipe, VHSH 30m ....always had a little trouble jetting it right ...Concerns are gone down to a DP 264 atomiser,.. U16 needle on top clip .. which seems very clean almost to lean but a nicer ride , come down a clip boggy mid range!!
Most Recommendations for this combo telling me dp266 atomiser, u16 needle 150 main ...... to be careful running the dp264!! tried Various K needles K8 K5 K21 which have all resulted in no joy ...
Anyone else on such a lean set up ??
Lambretta Sash
Main scooter: Lambretta TV 230
There very good carbs once set up, best place is a dyno. Ive run down to dp262 and 60 slides on some set ups and never use U needles if that helps
lou
just going on what most recommend .. but engines are all different i surppose , problem geing not got any scope with being on top clip ... any surggestions on what needle to try ?
    Users browsing this forum: Majestic-12 [Bot], Semrush [Bot] and 10 guests
