T5 aly with a 152 polini conversion.
ducksta
so sean is this something you could do
I can and often do do it ,but only as part of a high spec full engine rebuild/tune as a rule.
we are really far too busy at the moment to take on any more jobs at all ,even just smaller jobs like that i,m afraid matey ...
fastfrog
begining of the welding job:
Size matters!
fastfrog
Size matters!
fastfrog
casings shut:
Size matters!
fastfrog
squish 1,10 mm Seems ok to me..
Size matters!
guygrrr
Main scooter: 1980 Vespa P187
Great stuff FF ! I really enjoy yr threads.
more can do, less doodoo.
fastfrog
Many thanks mate.
But crack is back again...
Size matters!
fastfrog
back to the flame job again. This time is the right time. Carmello cut the cracked hole and double welded from outer and inner side.
not much room left:
Size matters!
fastfrog
Engine rebuild, and back into the frame:
ignition set at 25° BTDC for a Kheper programmable unit:
Next step: get me a lightened original flywheel...
Size matters!
