t5 172
soulboy
is the head gaskit needed
ducksta
no
jackson85
Main scooter: T5mk1
Do you have the original head modified? My understanding from the Malossi instructions was you use the gasket withthe standard head. Modified ones are normally setup for no gasket
goldeneye
get a proper head, itll be cheaper than the 3 pistons you"ll f@@k up before you realise you need the proper head.......
paul d
Main scooter: T5 172 Tv 240
If you modify the head as it says in the malossi booklet you need to use the gasket. I dremmelled the combustion edge at a 45 degree angle as per malossi instructions, used the head gasket provided and ran it flat out for the life of the first kit (4 years) but the compression was very high. I add 1% oil to the tank along with the autolube too. Always fully synth....well nearly always!
soulboy
I have got a proper head I think I got it off ducksta
ducksta
which scoot soulboy if its off the hybrid its been machined correctly, but i havnt sold any t5 heads :!: there like rocking horse shite
soulboy
I swapped it for my standard head he may not have been you pal do u use a head gaskit
ducksta
my head has been machined so no gasket used
    Users browsing this forum: Google [Bot] and 16 guests
