isnt the melting round the edges caused by debris from the holed piston travelling up the transfer ports and becoming trapped between the head causing localised overheating here
the exhaust side seems clear
Holed Piston, Any Ideas Why?
davidblythe
- registered user
- Contact:
- drunkmunkey6969
- Moderator
- Contact:
Can you post the Air/Fuel graph?soulsurfer wrote: It had just been dynoed and with EGT guage a 700 degC spike at this speed which, on a TMX30, I tried to jet out without success.
- soulsurfer
- registered user
- Contact:
No, I didn't get a copy, but I saw the screen in real time. The spike didn't show up on the dyno, only on the roaddrunkmunkey6969 wrote:Can you post the Air/Fuel graph?soulsurfer wrote: It had just been dynoed and with EGT guage a 700 degC spike at this speed which, on a TMX30, I tried to jet out without success.
At what revs did the engine make peak power on the Dyno..?? and at what revs would you have been riding it at when it popped..??
- sean brady scooters
- Dealer
- Contact:
i would guess at between 5...........6000 revs..............depending on gearing
So if riding at this say 6000 rpm, where the strongest pressure wave returning from the exhaust would increase the chances of it detonating, more so if there was an already underlying problem... Maybe.??sean brady scooters wrote:i would guess at between 5...........6000 revs..............depending on gearing
- soulsurfer
- registered user
- Contact:
Peak power was 21.27bhp at 7500rpm. Gearing is LI150, 16x47 rpm at the time would have been around 6500rpm.J1MS wrote:At what revs did the engine make peak power on the Dyno..?? and at what revs would you have been riding it at when it popped..??
Forget that then.... Maybe the ignition might be somthing to check, as Avantone says.... but it may still be a combination of more than one thing which makes finding the cause of this melt down a little tricky... have you managed to get a full print out yet from the dyno..??soulsurfer wrote:Peak power was 21.27bhp at 7500rpm. Gearing is LI150, 16x47 rpm at the time would have been around 6500rpm.J1MS wrote:At what revs did the engine make peak power on the Dyno..?? and at what revs would you have been riding it at when it popped..??
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 4 guests
