Exhaust end can
Evesy
Main scooter: Jet 200 with Imola 186
I'm going to be changing the end can on my dev tour pipe to something a bit more trick. The question is will this affect the jetting or is it relevant just when you change the whole pipe. Cheers boys.
wack 63
Main scooter: '71 GP TS1
As long as the internal baffle tube isn't smaller diameter it shouldn't make any difference
Lamaddict
I asked a similar question a while back as I once read something about the differences with length etc but didn't really get an exact answer.
camel
ive used a crosser can to dampen the noise on my ads3,as previously said make sure the bore of the pipe is no smaller than the origional,my can is a little longer but it hasnt affected performance
