Exhaust bolt
Jxmiddle
Main scooter: GP250 69 targa twin
Anyone tell me what size the bolt is that fixes the exhaust into the underneath of the crankcase?
Ta.
Jxmiddle
Thanks m8....
Any suggestions if this is stripped?
Thanks
Grumpy225
Jxmiddle wrote:Thanks m8....
Thanks
permacoil, helicoil, timecert or weld and retap.
Coils are easy to install (most of the time) and are cheap compared to welding. If done correctly it will be stronger than original since now it will have steel threads instead of aluminium ones. Repair kits usually run about $20-$30 and come complete with tap, coils and installing tool.
stokky
be careful though, can't tell you how many engines I've seen over years where someone has used a bolt thats too long.
Gone straight through into engine
Makes a good oil drain !!
Timbo
Does anyone actually bolt their exhaust to this point?
Jxmiddle
Just fitted the BGM big box and they told me this fixing point is essential. Fortunately I have the right size helicoil kitImage
lambro
Timbo wrote:Does anyone actually bolt their exhaust to this point?
Just fitted a new exhaust today, and whoever fitted the previous one did bolt it there.
I must have wiggled and tapped and wiggled and clouted it for 5 minutes before I realised :oops:
dapper
Yes, but I've fitted exhausts which have the extra bracket but it in no way lines up with that lug of ally on the bottom of the casing :shock: :? :o :roll:
    Users browsing this forum: Baidu [Spider] and 5 guests
