finally on the road!!!
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
Don't quote me on this, but it's not a good idea to run in on fully synth. I always understood it stops the rings and barrel wearing to each other. Possibly that's why it's smoking like a good un. The rings aren't seating properly.itwillrunproperly wrote:Still needs to be run in, don't no why she's so smoky, using SIP fully syn oil 3% mix.
- Main scooter: Lambretta 1962 S3 Li125
Doom Patrol wrote:Don't quote me on this, but it's not a good idea to run in on fully synth. I always understood it stops the rings and barrel wearing to each other. Possibly that's why it's smoking like a good un. The rings aren't seating properly.itwillrunproperly wrote:Still needs to be run in, don't no why she's so smoky, using SIP fully syn oil 3% mix.
That's a very interesting and valid point, what do others think? I know 2-strokes do smoke a bit but to me I don't remember seeing this amount of smoke, It does really smell like 2-stroke oil burning that sweet smell you get and not crankcase oil, as I say I covered the exhaust she cuts almost immediately, so guessing the drive seal is ok. I wonder if I drain the fuel/oil mix out (just filled her up with oil/fuel mix 8ltrs
- Doom Patrol
People do swear by mineral oils for running in initially and you can get some good ones. Probably a good idea is to go down to the local motorbike shop and see what the kids are using in their peds. You can work your way up to a good semi.
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
I tend to use semi synth at 4% running in.
I also do a lot of "short sharp cycles" ( cold start; blat around the side streets for 2 or 3 miles; up and down the box; use the engine braking a lot; back to base and let cool- then repeat)
I tend to give the engine a fair bit of welly in each gear but DON'T let it labour or overheat.
Scootering since 1968.
cheers - will drain off fuel tank and try over w/e
- Scootissimo
Are those drops?
yea they be
Originally had TV/SX throttle bits but found that the GP ones worked better, deepened the cable slots as the throttle and gear cables tended to ride out of their grooves due to the acute angle of the handlebars, work fine now
Apart from one m/c shop, Zero everything else unfortunatelyDoom Patrol wrote:People do swear by mineral oils for running in initially and you can get some good ones. Probably a good idea is to go down to the local motorbike shop and see what the kids are using in their peds. You can work your way up to a good semi.
