Mugello 198, Delly 25mm, ScootRs pipe - jetting?
alanscottj
Hi folks, I have just fitted a Mugello 198 kit and am having some jetting issues. My set up is as follows:
Mugello 198
Dellorto 25mm carb
Scoot Rs Exhaust
Main - 98
Atomiser - AQ266
Choke - 60
Slide - 40
Needle - D22
53 pilot
RamAir remote filter
The scoot starts first kick (even from cold), accelerates beautifully and rides lovely up to half throttle, any more than half throttle and she loses power.
I am only just running it in so can't take it to the dyno until it is run in so any help would be appreciated so as I don't damage the kit in the mean time.
Many thanks
Scott
Weston-scooterist
Main scooter: Lambretta LI150 Special
I had a very similar setup, only difference was a 264 atomiser and a 100 main, id up main jet to 105 and see if this cures it
paddyfitz
Maybe try a D26 or D29 needle. I've had good success with those...
alanscottj
Weston-scooterist wrote:I had a very similar setup, only difference was a 264 atomiser and a 100 main, id up main jet to 105 and see if this cures it
I have a 105, will give it a try this morning, thanks 8-)
alanscottj
paddyfitz wrote:Maybe try a D26 or D29 needle. I've had good success with those...
Would I have to change the atomiser to try another size needle?
alanscottj
Tried a 105 - no difference
Tried a AQ268 atomiser and way too rich - loads of fuel coming out of air intake
Might try a d26 needle?
    Users browsing this forum: Majestic-12 [Bot] and 4 guests
