There are some far better pictures of shock absorbers and what they are absorbing on that site than www.hilevel1.co.uk !!!!
A good rear shocker choice that's adequate.
gaz_powell
"I Googled Hi Level shock absorber and all I got was sports bras. I think you'd better tell us some more to avoid further embarrassment."
speedy
- Main scooter: lambretta af s type ts1
Will try the c spanner tomorrow when I get it and try, cheers mi duck.belly wrote:I've had mine for 2 years now and spring doesn't rotate, have you wound up the preload to max, you're just a little heavier than me, but
mine is wound up to max
Toot-oasc
- Main scooter: Lambretta
Have used an Escort shock on my TS1 for over 4 years now, and although I'm not quite as light as I like to think I once was, there's been some weight on the Lammy when I've been two up and carried lost of Club Shop stuff on the backspeedy wrote: I have for several years now, just used Escort rear shocks on me Lammies, a chrome one to suit the bike, but have just had one fail on the bushes. Now I know they are not the best, but they do the job of carrying me and my luggage around the country, Speedy
If they've been good enough for a few years, then why pay a fortune for an expensive shock that you have to make fit and have doubt in your mind every time you overtake a lorry??
Just my own opinion of course, however I only have products I have full belief in, available through the Club Shop.
speedy
Good point Toot. I have as I mentioned used Escort shocks for many years on and off, without issue, and it's just the one that's failed me in fairness. I just wonder sometimes when you become a little....Portly,
if maybe something a little more heavy duty might do a bit better
cheers,Speedy.
- Doom Patrol
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
I like Escorts. They go up and down and do exactly what they are supposed too, absorb shocks. A nice, simple, robust shock absorber and most of the time they probably work just as well as a more expensive one.
speedy
Right I seem to have sorted my issues. I'm not getting a Hagon, instead I'm sending my faulty one off for inspection and hopefully repair. AF have said they can re bush my chrome Escort shock for between a fiver and a tenner, so that's good. Then on the advice of a good friend, I have bought a chrome adjustable Hi Level shock from Cleggy for £49.99. The bushes look very good and the finish is good, plus the damping dos seem to be what I'm after, just a little upgrade on standard, [ for this scoot anyway ], which is what I want. I'll let you know when it turns out to be a total pig,lol,Speedy.
