bgm flywheel/ varitronic stator
tea5ive
Main scooter: cometa 140
oes anyone know if a bgm flywheel will work with a varitronic stator ?. cheers simon
Grumpy225
No
BGM is a 6 pole flywheel (you can't see the magnets but there are 6 of them) where the varitronic is a 4 pole.
jonashford
I couldnt get it to work with any a kytronic or agusto
jonashford wrote:I couldnt get it to work with any a kytronic or agusto
BGM flywheel or Varitronic stator?
jonashford
Bgm flywheel
GP Kevo
I think those add-on boxes (Kytronik and Agusto) require a genuine Ducati CDI. There is a revised Kytronik that is said to work with all Ducati - Vespa PX type CDI's.
jonashford
bgm flywheel doesnt work with the agusto which has been out for ages, ducatti or bgm cdi!!!! which is poor IMO
jason frost
What was happening with the kytronic ?
jonashford
Timing was bouncing incorrectly between 26 & 16 degrees, put the Indian flywheel on & was perfect, believe me I tried everything then just gave up
jason frost
jonashford wrote:Timing was bouncing incorrectly between 26 & 16 degrees, put the Indian flywheel on & was perfect, believe me I tried everything then just gave up
Just setting mine up now with BGM flywheel,stator,coil and kytronic. Timing mark is spot on at 23, no movement at all when its revved on the 0 setting
    Users browsing this forum: Baidu [Spider] and 4 guests
