64mm (185cc)pistons- any good or shite?
Yes I've got a 64 mm Deanspeed piston. £60 + P&P. Or an SR 64.5 mm at £40 + P&P.
Darrell Taylor
Main scooter: LAMBRETTA
what are the pistons like quality wise/what rings 1mm / 1.5mm drawn wire ?
Grumpy225
I've been running the RT 64mm piston in my SR kit. Going on about 6 years and a few thousand miles. No problems.
djh66
Main scooter: 150 special
What about a Mtiaka piston from Yamaha RD 350, used in the GT186 kit?
Bring Me Sunshine COYH
djh66 wrote:What about a Mtiaka piston from Yamaha RD 350, used in the GT186 kit?
has cut outs for reedvalve
CPH Lambretta
Main scooter: DL 150 1970
And has a lower compression height so you would have to top and tail the barrel or use a longer con rod.
Slow is the new fast!
