Li 125 set up
Lamaddict
mick1 wrote:Muggelo, Casa, GT, would all be meeting your spec' or modify your casings to accept a 200 barrel (probably works out cheaper than buying a kit !!)
I've done 2 of these easy conversions, you're getting a proper 200 and yes it's cheaper than the other kits mentioned. I got the 200 barrel spigot turned down, drilled out the studs holes and used a 200 head, also drilling out.
davla
mikeveslam wrote:Think it will be the casa kit when I have got the coin with a new gp crank.
Cheers for the info lads
remember you'll need a GP flywheel as well.....
