Anti dive
newboy
I've got the scootrs disk on the front, can I buy a bolt on anti dive kit? Front brake is very fearce with out
Cheers
newboy
Nice one bud
The seller does say that the kit is not complete. The parts that's missing is the speedo housing cover which you need or you will need to get your existing cover machined to accept the bearing shims. Unfortunately you can't buy that part on it's own.
I sell the complete kit new, they're £80. The kit also comes with a weld on tab to use instead of the clamp but I don't think I've ever seen one where they've fitted the weld on bracket rather than the clamp, though my advice would be to use the clamp until you've decided on the postion of it then get the bracket welded on.
newboy
Got a kit for £70 in the end
http://bit.ly/1k6E5NM
