Runs badly after refuelling
Jxmiddle
Main scooter: GP250 69 targa twin
Anyone have any ideas?
Lammy is running fairly well (other than the normal crap you have fun with) but for about a year I've had problems after refuelling at the petrol pumps. It runs very boggy at low revs and will easily die, no tick over at all. And restarting is a problem (like the plug is fouled) - eventually I have to kick it over with the fuel tap turned off which indicates (to me) a flooding issue. After 10 miles or so cures itself and goes back to its normal idiosyncratic self.
I always turn the fuel tap off when I fill up and I've tried oil first, oil last and even oil half way through and it's always the same. It does not happen if I fill up from a fuel can.
Thoughts?
66 SX muggy 225, 30mil dell orto, gori exhaust (:-/)
fastfrog
float needle or a faulty ignition....
Size matters!
bristolmod
crap in tank disturbed by the force of the pump, but not when a can is used?
Scootering since 1968.
camel
what oil are you using out of interest?.i have a similar problem on one of my bikes,it dosnt cut out, it smokes like a barsteward for a mile or two after filling,this bike uses silkolene pro 2,which i hear dosnt mix too well
Adyonekenobi
Main scooter: Li150 Special, now TS1 225cc
Oil added after petrol?
Sinking to the bottom of your tank hence poor running.
Always jiggle the scooter after filling up! :-)
Spanner check the running gear before every outing, like in the Army. You know it makes sense!
storkfoot
Do you have a filter on the carb? If so, what type? You say it clears itself after about 10 miles. How does it run during this 10 miles and is the 10 miles around town or at WOT on the motorway, for example?
Jazzy
poorly sealing float needle,
Greater pressure (head) with a full tank.
Jxmiddle
I'm using castrol 2t. I jiggle it so much after fuelling its almost obscene :-/. It runs fine at high revs but almost like its not firing at low revs. As I say get none of these symptoms when I refuel via a can, only when its via the pump. I always turn off the fuel but now I think of it I haven't checked the fuel tap. Perhaps I sould check that and clean out the tank.
Stil if I'd wanted something entirely logical I'd have bought a Honda......
I always turn the tap off when refueling and restart it with the fuel off. After it's been running a minute I then switch the fuel on, sometimes a mile up the road when it conks out :oops: .
My first job would be to take the tank out and give it a good clean out to see what's lurking in there.
    Users browsing this forum: Semrush [Bot] and 22 guests
