Spaco 30mm - phbh replica
gaz_powell
anyone using them ?
was going to get a Dellorto PHBH for my TS1 but the tickover and air screw are on the side adjacent to the engine mount making adjusting a pain.
found a spaco version with them on the other side which will make life a bit easier
gaz
mick1
Main scooter: Li Avanti 225
I used a Spaco 30mm on my Avanti. I was always dubious as to whether it would not perform, or cause problems but it worked fine. In the end i did fit a Dellorto and TBH there was no difference in performance or reliability.
fastfrog
Hi gaz, why don't you just buy the dello PHBH BS model instead of the BD?? both exist and are very easy to get....
Size matters!
Special X
The spaco works very well but very hard on rubber mounts due to being much heavier then the Delly.
gaz_powell
"Hi gaz, why don't you just buy the dello PHBH BS model instead of the BD?? both exist and are very easy to get...."
the BS is the common one sold here and the air screw and tick over are next the engine mount on a TS
My vshb on my other TS is a LD and air screw and tickover are opposite the engine mount
Will see if I can a delly with them on opposite side given the heavy comment Special X - its the BD I want #
# update
B - Generally rubber sleeve "elastic" type fitting. A - Generally clamp type fitting. Other letters have no specific meaning - they have certain original applications - if you are unsure which model you need, contact us before buying.
S - "Sinistra" - "left" in Italian - Left hand idle mixture and idle speed screws.
D - "Destra" - "right" in Italian Right hand idle mixture and idle speed screws.
Thanks for the valued comments
Gaz
    Users browsing this forum: No registered users and 26 guests
