I received cylinder and FW cowl. obviously cheap repros..... Cooling needs a good sealing treatment... between mag flange and cowl is a 1mm space, between the 2 cowl is a 0,5cm gap... All this p155 me off..
I'll cure mag cowl space with a 1mm thick heat joint stuck in the inner side of the cowl. I'll try to cut the cylinder cowl and bend it against the mag cowl to get the whole thing more tightly fitted.
I put 2 T5 cylinder rubbers to avoid rattling noise between cowl and cylinder:
