exhaust stud
chippy
:bouncing: is it best to use the long bolts on the mounting bracket on a taffy pipe to the crankcase, or fit longer studs? thanks :bouncyeng:
wezly
if you mean the rear mount id use the 3 bolts provided, studs are better but you would struggle to remove the side casing.
chippy
wezly wrote:if you mean the rear mount id use the 3 bolts provided, studs are better but you would struggle to remove the side casing.
cheers wezly, never gave it a thought about removing crankcase side
