Poor running - Rapido 225
Funkspeed
Main scooter: Rally 200
Hi all,
Scoot was running perfectly when I first had her about 6 weeks ago. Generally seems to have gone off tune at lower revs. At 3/4 or full throttle is still smooth but anything below that shes spluttering and coughing and won't pull away very well in first. A bit of a pig in traffic when two up I can tell ya!
225 Rapido with 30mm Dellorto and JL3 pipe. Running on 3% oil mix.
I'm thinking she may be running a bit rich? Have done one plug chop with an NGK8ES and was a bit wet. Just changed to a Denso but haven't had chance to do a chop yet.
Any thoughts appreciated.
Rob
tarmac tickler
if it was running perfect and you aint changed owt and now its a "bag o s**t" and youve got a indian electronic kit on you can bet your life its either the pick up or coil ,,,
Funkspeed
Good point. I'll have to check what's fitted.
Cheers!
Personaly I'd be suprised if it is an ignition fault, you'd expect it to get worse at higher revers, not better.
I would look at your choke and make surem that the plunger nis fully sealing when it is turned off. Have a look down the little hole on the carb inlet. there should be a litle bit of slack in the cable as well.
Funkspeed
Could be that too as getting through a shed load of fuel and she seems a bit smokier than normal too. Another avenue to explore. Cheers
chris2470
If it was fitted from new 6 weeks ago you may need to re-toque the head bolts.
Best Regards
Dimitrios_231
Change in temperature?
As the weather gets hotter the engine runs richer.
tavspeed
check your circlip hasnt come off the needle
Funkspeed
Cheers all...keep suggestions coming as hope to take a good look tomorrow.
Whilst I think of it I need to sort a new clutch out....4 plate with stronger springs or 5 plate?
Funkspeed
Took the panel off and the inside is caked in sh1te...more than normal.
The choke plunger appears to be sitting where it should. Checked the fuel filter and about an eigth of it caked in crap...all cleaned and now she at least ticks over better. Haven't had chance to take her out for a run yet but does anyone reckon that the dirty filter would have caused the poor running as described? (I know it wouldn't have helped).
Does anyone else get the inside of their panels badly caked at all?
Cheers!
