Exhaust Wrap ...Again sorry.
shamrockexpress
What material is best for wrapping??
nellyboyo
Sod it......its like an itch I can`t scratch .....I`m going to go for it when I`m home next ..... :)
nellyboyo
Late news ,,,,did the wrapping and it DOES queen the pipe down but that's it as far as I can tell . Did wrap it a good 10 inches from manifold !
shamrockexpress wrote:What material is best for wrapping??
I quite like grandmaster flash myself .... white lines dont do it ......
Has to be the 12" version 8-)
Adyonekenobi
Main scooter: Li150 Special, now TS1 225cc
Hi
I wrapped the main body only, on my NK Road exhaust with the purpose of quietening it down and it does work.
Manifold pipe is uncovered and last tapering section to the slip on joint to the end can is also not wrapped.
Happier now with less tinniness and zinging sound, still sounds great without being too noisy.
I'm just getting older I guess?
Ady
Spanner check the running gear before every outing, like in the Army. You know it makes sense!
