Clubman or Sterling
philz
Main scooter: Lambretta Li150
Can I fit a Sterling exhaust to a standard Li150 or would the Clubman be a better choice?
philz
Anyone with any advice?
nellyboyo
Don`t fit either .....save for a tidy pipe, they`ll both fit though
If it's totally standard, you'll need to upjet with either. You'll end up using more fuel and making more noise and not gaining much.
If you're determined then I'd vote clubman
philz
I'm not really out to fit another exhaust. I am building it all standard but didn't know if the benefits justified changing the exhaust. I don't know how these exhausts "improve" performance is it torque or top end if anything at all.
Yanker
I once fitted my Mikeck to a standard LI125 "for a laugh/to see what it would do" for a day with a guestimate up-jet on the main:
It was approx 12MPH faster than standard with more power everywhere. No miracle there then, unless it could have made it go backwards that is....
If you' d have run it a second day it'd likely have popped yer piston ...
