Tyre Size??
eadmr04
Might sound like a stupid question but what's the difference between a 3.50 x 10 tyre and a 100/90 x 10? Was looking for a Michelin S83 and found a 100/90's in my garage which came with a scooter I bought?
100/90 is a bit taller than it is wide, can affect you final gear ratio if used on the back. Usually also held to affect the a handling too
3.5" is 88.9mm.
