tmx 35
roadrunnerian
Hi i'm running a ts1 225 with tmx 35 and franspeed race settings are main jet 320 and needle 57 2nd clip down this seems a slight bit weak scooter is running great and settings are about average any ideas thanks
They do run great when lean, at their best just before they go bang. Check the settings that others use on the Lambretta carb set up page, from memory I think 58 needle was the most widely used. Plug checks are the way to go.
roadrunnerian
i've looked at the settings alot are using a 57 needle went back to a 56 but slightly rich can't win lol thanks for the reply Corrado
I'd opt for rich and safe anyday. What's the 57 like on middle clip?
roadrunnerian
will try 57 needle on next notch down thanks m8
Boo
roadrunnerian wrote:Hi i'm running a ts1 225 with tmx 35 and franspeed race settings are main jet 320 and needle 57 2nd clip down this seems a slight bit weak scooter is running great and settings are about average any ideas thanks
Hi, had simular set up to yours, what pilot jet are you using and whats it like around quarter throttle?
Lambrettas are for life!
