RB20 (200cc) - Pictures and Spec
Knowledge
I notice from Dan's etching above, that the distance from the base of the transfers/exhaust port is 59mm. Hooray. It needs to be 58mm to match the stroke, but it is often 55mm on the RB22, leading to some really wild transfer timings on the bigger engine.
It is certainly a tempting kit....... I have some welded-up cases, and a GP crank with a 116mm rod already fitted. Nice. Unfortunately, the rod is a standard TV item, so it is unlikely to withstand 22bhp.
Martin
truls221
Hello my first post here.
I wonder just if there are any port maps of the RB22 for comparison.
The kits looks the business, but I wonder where the two sub-exhaust ports have gone taken.
I don't drive lambretta sadly enough (not yet).
but I always look at the fine workmanship done by lambretta lads.
if someone would split their port map for the RB22 it would be of great interest.
cheers on the m8
truls221 wrote:if someone would split their port map for the RB22 it would be of great interest.
I have something better....give me 20 mins to organise a fresh thread. ;)
truls221
That would be good!
CPH Lambretta
Main scooter: DL 150 1970
Anyone know if a 58mm MEC race crank could be split and uprated to suit this new RB20 kit?
Cheers Nick
Slow is the new fast!
CPH Lambretta wrote:Anyone know if a 58mm MEC race crank could be split and uprated to suit this new RB20 kit?
Cheers Nick
I believe so...AF can do this for you.
fishi
Hi,
he means a portmap to compare the RB22 and RB25, I think.
fishi
J1MS
I'll go get my EtchaSketch!
ArKaTxU
News about the kit?
In LTH Germany there are RB20 kits with diferent pistons.
With Vertex Pro and Wiseco pistons.
You know the diferences using this pistons?
