indicators
soulboy
put some tiny ones on the back to replace the old tiny ones and new ones wont flash there normal bulb type ..the front ones r fine so I don't think its the flasher unit or is it cheers
soulboy
all im needing to no is the front flash and the back ones don't so is that still the flasher unit
re check the connections ,make sure the live is working and then the earths
soulboy
thanks once again mate ;)
did you get them working again then ?
ducksta
they come on then off again then on then off again carnt seem to work it out :D :D
soulboy
it was the flash unit ;)
    Users browsing this forum: Google [Bot] and 21 guests
