107 rod to 110 ?
Mark ULC
Main scooter: LI Series 2
Yes these kits use a head gasket.
Muppet
Mark ULC wrote:Yes these kits use a head gasket.
why?
C’est la vie
boris
Main scooter: lambretta
My kit does not have a head gasket MB advise to use loctite to seal head.
Sent from my HTC Sensation Z710e using Tapatalk
eden
The plot thickens!
Mark ULC
[quote="boris"]My kit does not have a head gasket MB advise to use loctite to seal head.
Your correct Boris no head gasket supplied with the kit :oops: I will retire to my dark room.
But MB supply one if needed and the instructions advise to fit head and gasket. I give up :roll: I admit I did not build the top end and shall say no more.
boris
I think the gaskets are only ment to be fitted to use as packers.
Don't quote me on it though.
Don't get me wrong the kit looks so well engineered and finished off it would fool any novice like my self
But I have had enough of it now.
4 pipes 2 carbs later and looking at a full strip down to change crank.
I have decided to change to another kit that I will all most be guaranteed the performance the RT promised but did not deliver.
jason frost
why?
Why not
jason frost
boris wrote:I think the gaskets are only ment to be fitted to use as packers.
Are you anywhere near Sheffield ?
boris
I'm in Hull.
jason frost
Bring it over and let my have a look at it FOC
