varitronic difference between ultimate & normal
shureimage
Main scooter: SIL GP200
Hi, As subject says, whats the difference between ultimate & normal varitronic. I've read its strengthened (how ?) is anything else done ?
Cheers Dom.
Speed Demon
The flywheel and boss are also welded with a special rod because they are made from different metals. IMHO this is highly advisable on Varitronics used on anything revvy or that produces much over 22hp.
Get to SULK
jason frost
Speed Demon wrote:The flywheel and boss are also welded with a special rod because they are made from different metals. IMHO this is highly advisable on Varitronics used on anything revvy or that produces much over 22hp.
Last one I had, only the rivets looked like they had a tig torch near them.
Speed Demon
Did you take the fan off Jase - one's we've had have also had beads of weld from flywheel to boss on 4 points around the flywheel but it's hidden by the fan. Could be different on the new type though.
Get to SULK
jason frost
Will have a look, need to set the timing on it so will check, thanks for letting me know :D
soosh
Anyone had to weld a Ducati flywheel from an old AF kit?
shureimage
OK cool, cheers for that, so basically if I get my flywheel welded it becomes the ultimate, nice one cheers again Dom.
    Users browsing this forum: Google [Bot] and 7 guests
