i said that if im using a 60mm crank, when the piston is half way between tdc and bdc ie 30mm down the bore it will be at 90 deg (180 deg port timing) .
He said no its not like that, its more or less than 30mm something to do with conrod length and angle ?? this sounded a load of b@ll@cks so i went back in to the garage to check and prove him wrong ! as it seems like basic geometry to me. ........however, i had to eat my words
so can someone please explain as my heads hurting trying to work out why
